M
mdf290
I don't really have issue with wireless systems, or that they can be jammed. The Yale system however has a number of flaws that are unforgivable, mainly that the code is sent in the clear when using a remote keypad.
But the alarms would stop an opportunist thief.
if someone is going to the bother of using a grabber then its hardly an opportunist.
Even if the code is grabbed it's unusable except in certain conditions.
If you transmit that code to emulate the keyfob will it be accepted or will the sender have to also send the devices individual serial number that has been learnt into the system.
In any case the entry door would need to be opened to start the timer countdown before the code would work.
Or are you saying that the code could be read from the scanner in a readable form so you can manually input the code?
What then?
If the entry door is not used then you will have to go through a protected zone to get to the panel so you would have already set off the alarm.
If the entry door is used to start the countdown then if it's a front door you will have to pick the lock or smash the door. Not something that I've ever come accross in four years of working in burgled homes.
