What should I use to fill in hearth before laying flooring
28 Mar 2011
London
Hi
I've removed the hearth which was bedded on cement and this area is lower than the floor boards.
What should I use to bring this up to the level of the adjacent boards?
Will I need any membrane over this area or will the normal foam underlay be sufficient?
Thanks in advance
Thanks - does it need to be a full blown membrane or will a sheet of heavy duty plastic do?
