I have been having trouble getting a reliable joint between the blue 25mm MDPE incoming main and the 22mm stopcock.
The first issue is the SWWater supply pressure which is 12bar!
The second issue is the transition fitting from MDPE to copper before the stopcock and the pressure reducing valve.
I first had a blue pushfit to female thread plus compression copper fitting and then a short length of copper pipe before the PRV. This connection failed after a few months due to the plastic thread distorting and no amount of sealant or tape on the thread would hold.
Changed the fitting to push fit blue to push fit on to the copper, this too now leaks at the copper end after about 6 months.
How can I get a good leakproof joint between these two pipes? Is there another way of achieving this transition?
I'm fed up with constantly having to redo this joint. Any ideas?
