I posted here a couple of years ago for help with wiring my electric outboard engine to the battery, below is some of the post I made
I have an electric outboard engine that I am going to link to a 12v battery via a 50amp circuit breaker as recommended by the Owner's Manual, The engine is 12v 52A input and 624W Input Power. The manual says to use "6 gauge wire AWG" for cable extension.
The guys on here recommended that I either use 16mm meter tails as I was only extending by 1m, or doubled some 10mm cable from some T&E cable I had at home to make 20mm. The cable would be fixed with no movement, so no wear and tear. This has worked fine.
I'm now wanting to move the battery further forward for a better centre of gravity due to it's weight, and want to extend the cable to a maximum of 3.5m. I ended up using meter tails the last time as the length was ok, but may use the T&E solution due to costs, as I have it already, unless advised differently.
Will the recommendations given above still be ok for the increased distance?
Also if the T&E option is ok would it be beneficial to use both the red and blue + the earth as one cable as opposed to doubling a red cable? I would then colour code each length of T&E to red and blue as appropriate.
Thanks again in advance for advice given.
Read more: http://www.diynot.com/forums/electrics/cable-wire-equivalent.325731/#2414221#ixzz2VGujOkBv
