Hi All
People who have seen my previous posts will know im having to sort out the wiring in every room as i move through my new (1930s) house as there arent enough sockets, spurs from spurs etc etc....
Anyway, as im going underneath my hall way i thought i might as well sort out wiring under there for when i get my new CU fitted later in the year.
Im going to put in cable from the CU to 2 adaptable boxes:-
.... 1 on the drive wall for the garage CU which im kind of happy with the dimensions and ill be using 6mm2 from CU then 6mm SWA from adaptable box 1 to the garage. Suggestions are welcome;
....The other one is just going to be 2.5mm2 from the CU to the box then 2.5mm2 SWA to 2 maybe 3 front garden lights. What size adaptable box would take the 2.5mm2?
Thanks for you time..
