Is there such an electrical switch which allows you to choose which immersion heater to use in a tank?
At the moment my hot water tank has 2 separate heaters, each 3kW rated. There is a cable running out of each of them which I can plug into the wall socket one at a time.
I know this is not best practice wiring so I plan to put in a switch to choose which immersion heater to use and then wire in a timer to choose the on and off time.
I wonder if a selection switch exists to allow me to choose the heater I want on which can take a 3kW load?
