- Joined
- 19 Jan 2013
- Messages
- 22
- Reaction score
- 0
- Country
I got a stove installed in my living room last year. It's a DEFRA-approved clean-burning stove, which means that you can't close it down completely. As a result when it's not in use (which is only 2-3 times a week or so - Central heating is fine and the fire is for fun only!), there is a small downdraft into the living room. It's not a major problem, but as I'm a bit of an efficiency freak, I'd like to stop this draft.
I've looked at chimney balloon, but most of them are large (to fit an entire chimney). The house doesn't have a chimney, so there is an external flue that goes up to the roof. The internal diameter is 5" (~150mm). Does anyone know of any chimney balloons for the purpose of putting in a flue-pipe that is easy to use and remove before each fire and put back the following day?
Thanks.
Thanks.
