You don't get it, do you.The Excel kit came with a single copper line bus. If you need a mix of RCD-protected/unprotected circuits you have to cut this. There was nothing in the kit that said anything about this.
There didn't need to be anything about that - fitting a CU is not like changing a plug, and anybody who was truly competent to do it would have known that he had to cut it.
Valueless.The original Question was whether Excel units were OK and I posted my opinion.
He did a full EICR did he?The man from Southern Electric tested my wiring and it passed the insulation test.
Has he come back to carry out all the live tests following your CU replacement?
Have you thought about what you'll do when you sell the house and you get asked if you've done any work which needed Building Regulations approval?
Not fit for purpose for t**ts who are so ignorant that they should not contemplate replacing a CU, and so stupid that they go ahead anyway, you mean.As supplied, this unit was not fit for purpose because it did not contain important information. That's my warning to would be buyers.
