Tidying up the bathroom
26 Jul 2013
Surrey
Ok, not long moved in and did want to have bathroom completely ripped out but after having a new fitted boiler, electrical work, and work on windows budget is not looking too healthy!
For the short term I was thinking of keeping existing bath, tiles, floor and just getting rid of taps, shower head, plug fitting, and any bathroom accessories that previous owner had fitted.
One thing I have noticed is before I even start there are already a lot of raw plugs fixed in the tiles and assuming there will be more.
What is the common thing to do with these? Do you pull them out and fill with something?
Also noticed that there is mildew running in the corner of bathroom where floor meets skirting. Same corner where shower curtain is hanging.
I'm hoping this is where previous owner just left the shower curtain dripping rather than anything serious!
Apart from treating the area, is there anything I can use to seal the area? There is a gap around floor tiles where it meets skirting? Are these expansion gaps like with Lino? Should these be sealed?
pull the rawlplugs out and fill with silicone or grout.
The gaps at the edges - no they just sound like a bad fitting job, no need for expansion. depending how big they are fill with grout.
Skirting - not a lot you can do really apart from paint it.
All of the above will be quick fixes designed to get you through until you can get the job done properly
I bought silicone to go around bath etc can that be used for edging around floor tiles or does it need to be grout specifically?
First of all wash the bathroom down with a good quality anti fungal wash such as one made by Black friars dig out any untidy silicone and let the bathroom breathe
Open a window for as long as you can letting everything dry out properly
Then you can do all your minor repairs as already stated with silicone
I suggest you check that there is a fan in the bathroom and its is working correctly not just one that is connected to the light switch
Ideally you want one which has a humidity ,this will cut in automatically as and when needed instead of working of the lights
