We have moved into a new house and I have just gone to change a spotlight that had blown when I found this! The bulb prongs are connected to the live wires via a block. On further inspection upstairs, I found some transformers with equally suspicious wiring so think each of the 9 spots are daisy chained from the transformers around.
My question is, obviously the light fittings need to change and have fire hoods as well, but can I connect the current wiring ring to the correct connectors via a block instead of having to change the entire wiring ring and possibly transformers (if I can get to them?!)
Thanks all!
Thanks all!
Bedroom spots
- Stuey444
- 1
Daisy chained from transformers (I think) wired into block with bulb prongs into other side of...
