- Joined
- 27 Jan 2008
- Messages
- 29,004
- Reaction score
- 3,555
- Location
- Country
BAS makes a good point once you read the bit which says it is exempt you stop reading.
As to what other non scheme member electricians do I don't know but personally I tell the owner:-
This work is likely notifiable I am not interested in contacting the LABC myself that's up to you to do. When you say I can go ahead I will start and if you have been given any stages where they want to inspect I will stop at those stages, and when complete I will issue a minor works or installation certificate in duplicate so you can send one to the LABC, but I am not doing it for you as so often there are other items to be added to the application, as well as electrical.
There is no permit to work system from LABC and where I know it has been registered I rarely see the building inspector so I am unaware if the work has or has not been registered. Although now I do very little so not really a problem any more.
I have only glanced at the new English Regulations only 8 miles away but rarely cross the boarder bus pass will not work. But for non scheme members one does not really want to get involved as I have all too often found during the work extra are requested and one just does not want to have to return and submit another plan. Just too much hassle plus if I pay the LABC I may fail to get money back where if they pay then I have less to worry about.
It says it's the owners responsibility so I leave it to them.
