Quite puzzled with an issue I am having with outside lights.
I have an isolation switch in my garage that is connected to my (old style) consumer unit with a 30a re-wireable fuse. In the isolation switch there are 3 20a fuses that previously fed 2 outside lights and took power to a shed. Before I moved in there was clearly an issue with the power going to the shed and one of the outside lights.
I don't need power to the shed and 1 of the outside lights was already disconnected (cable wa cut) so I stripped out the power to the shed and got rid. I checked all the connections for the 1 remaining outside light, replaced the fitting and successfully powered it up.
The other outside light had a cable that looked a bit perished and had no switch as it was directly powered from the isolation switch. Today I replaced the cable and the light fitting, and wired up a new fused switch so the light can be switched on from inside the garage. The light also has a separate sensor and so it will come on with movement but I wanted the switch so I could switch it off in the daytime.
Having wired everything up the light isn't working. I bypassed the sensor and I am getting power all the way to the light but it just doesn't come on. I have checked the bulb and it's fine. I even took the fitting down and wired it temporarily to some short flex and it worked. I tried a separate fitting that I know works and it still didn't work.
I have reached the end of my trouble shooting capabilities and wondered whether anyone had any suggestions. It's not critical and the entire electrics will get replaced in due course but I am baffled as to why the light won't work.
I thought maybe it was voltage drop or something like that but it's only over a short distance and the other lights over similar distances are fine.
Any ideas?
D
Any ideas?
D
