Hi all, I am new to the forum, just looking to get some advice on a job I am doing. I am of a electronics background so forgive me if I get confused regarding anything above 24v! I have a decent knowledge of electrics although I am not up to date with the regs in anyway hence my visit to this knowledge bank!
I am looking to put power and comms to four sheds. I have had a local sparky to assess the situation although he was only around for 10 minutes so didn't give me the full story, as I just need to know what cables to lay as I have the next week off. I am doing the donkey work he is making the final connections testing and signing it off.
The proposal is to add a RCD switched fuse after the switched fuse I already have (meter is >3m away from CU) and for me to install 3core 6mm SWA to an RCD disboard is the main shed 25m away. From this disboard he recommends that I just install 2.5mm SWA to each of my sheds which 3 are 15m away and the 4th 30m away.
2 of the heds 15m away will only have small loads; light and socket for the odd power tool, the other one at 15m and the one at 30m I may be making it into a potential office and/or playroom in the future. All will have a small disboard for lights and sockets all rcd protected.
Does this seem reasonable to you?
I am a bit confused regarding the suggestion that 2.5mm seem correct for the radials? As I would of assumed 4mm was the norm for radials.
I am not sure I gave him the full story so I am just making sure everything knits together before purchasing the cable and burying it 500mm down with additional conduit for the comms.
Any thought are very much appreciated!
