Let me explain... I am recessing a TV between two studs in a partition wall, The tv is exactly the right width to fit between the studs so I can't fit any plasterboard on the sides.
I will use a corner bead to make a frame, this means easi-filling over plasterboard on the main wall (with scrim) up to the corner bead, but over stud work in the recess.
Should I just PVA the timber and scrim it or do I need to apply something else to the stud timber first so it doesn't take the moisture out of the easi-fill?
Let me know if this was badly explained and you need you need a picture!!
