And what positions are the cables at the downstairs switch to landing?
Is it red=Com
yellow=L1
Blue=L2
Is it red=Com
yellow=L1
Blue=L2
So all the blacks were originally connected together and still are?From what you have all said, I believe i can deduce and identify the below:
A 3 core that goes to the downstairs switch (the one not going into the blacks)
A 3 core that goes to the extractor fan (blue going into all blacks)
A 2 core that is the permanent feed (without the red from it nothing works)
A 2 core that goes to the landing light
I think a 2 core that's the bathroom light
So by elimination we have an A.N. Other
If so, have you checked by use of an approved voltage tester, which is the perm live at the switch?
The black is at neutral loop yes?
we require a link cable between
com on gang 2 and perm live at L1 on gang 2 (to make gang 2 live)
Then the two core of bathroom light
Red to L1
again black is already at neutral loop?
That should make the bathroom light come on/off.
Now ideally we need to know where the core colours are at you ex-fan isolator, to determine where perm live is and switch live.
But putting red of the three core at com and yellow at L1 of gang 2, may do the trick. As blue is already at neutral loop.
Check that fan comes on with bathroom light and overrun performs as it should.
sorry I made error there, the link goes from perm live of gang 1(landing) to com of gang 2 (bath)we require a link cable between
com on gang 1 and perm live at L1 on gang 2 (to make gang 2 live)
Just so I read that right, a link cable between com and L1.....on the same switch? I only ask as that's what I was asked to take out on an earlier post.
Should it read com on the bathroom switch to L1 of the landing switch?
Red to L1
Is that with or without link and with or without red of bathroom light connected?Red is now in com
yellow in L1
result is..... fan comes on via the switch, and stays on for a couple of mins, then turns off!![]()
With only the light red cable left, I can only wait til tomorrow to see if it works.
Verrry close, I'll let you know how it works out tomorrow!
Thankyou ever so much to everyone that's lent me their thoughts and words!
So we do have one core left not yet terminated?The final cable that's not plugged in yet which I assumed was the bathroom light.... if it's unplugged, the other bedroom light and bathroom light with air vent stop working....
If the cable is switched at another location then this cable would terminate at either perm live of gang 1 or gang 2.So I am guessing it possibly needs to go either into L1 for power on the landing light, or into comm on the bathroom switch?.....
Yes this needs to be confirmed (I can be done by testing out if no lamp is available), but if I understand you correctly, the spare red is a loop to bedroom/en-suite with another functional switch near that location? This can be terminated at either gang one or gang two at the perm live link connection, if terminated incorrectly at either gang, it will only function when either gang 1 or gang 2 present a closed circuit.I know i have to wait for the bulb first....
Did the fan ever overrun?
