I see frequent references to the need for junction boxes to be easily accessible. As most (older) houses seem to have a mix of looped-in-at-the-rose and junction box-fed lighting configurations (the latter entailing a number of them located beneath the floorboards and carpet in turn), does this mean that this configuration now falls foul of the regs? Or did it always?
On a related note, I'm about to replace a light which hangs below a tiled floor. The new fitting's rose has minimal space so I plan to terminate cables in a choc-box and push it into the void. Does the hole made (t'will be a new one as I'm relocating to find a joist) simply need to be big enough (once plastering is done) so it can simply be dragged back down again for inspection?
Thanks in advance for any advice (oh, and sorry if this has been raised before)
Edit - soreeeee !!
Hadnt read the past couple o' days posts - didnt see Bonce's post below on similar subject ! To salvage my pride though - can someone still say whether my proposed for new light is OK .....
Edit - soreeeee !!
