28 degree pitch/Redland 52s
7 Dec 2012
Warwickshire
Hi
Can anyone tell me if Redland 52 tiles are suitable for a roof with a 28 degree pitch? We're having an extension build and I'd like the tiles to match the house.
I guess I'd better check the headlap of the tiles on the existing roof.
Why?
The headlap varies for pitch, anything from 75mm-100mm. These tiles can be used from 17.5 degrees(sorry forgot how to do the degree sign) up to 90degrees as long as the correct fixing specs are followed.
That's exactly the information I was looking for. I guess the roofers will work out the headlap. The current roof pitch is 37.5 but for one reason or another, part of the extension will be 28 degrees. Will a variance in the headlap be noticeable or would the roofer just copy what is already there?
The headlap on both those pitches can/should be 75mm so will not pose a problem. Any slight variation will not be noticeable.
So if I measure my existing headlap I'll be able to see whether it is appropriate for 28 degrees....or rather I'll be able to ask you taz :lol:
Minimum Pitch & Headlap
17.5°at 100 mm headlap
22.5°+at 75 mm headlap
Well I have been using a computer for more than a year and I still don't know were the degree sign is hiding :shock:
