CM7xx is the contract range. I don't it has the external sensor function. If it does you need to buy the sensor which comes with a little plug that goes into the back plate.
Thank you. But how does it sense the external temperature. The LCD indicates, what I think is the room temperature, so there must be a sensor somewhere, I would think.
Thank you - but where is the sensor located? Top, Bottom, side?
I am trying to put something cold against it, to lower the temperature that the sensor is sensing (if you understand what I mean).
