I have a Riello Mectron 5m burner. The hydraulic ram operating the air shutter began to leak.
I replaced the ram, but the capillary tube end no longer makes a good seal. Oil everywhere.
I've ordered a substitute capillary tube from a UK site. I hope that works out.
In case that fails I ordered a blanking screw to the pump hydraulic port.
However, My burner is an older model and the air adjustment is made with the shutter.
I can not simply discard the shutter even if I disable the hydraulic ram - I must fix it into the p roper position.
What is the best way to do this - to fix the shutter into a frozen position?
Can this be done by extending the length of the ram?
