I would like to install a 1 or 2Kw electric fan heater into my bathroom which is through the wall of the cupboard where the hot water tank is.
Would I be able to connect the fan heater cable (Live and neutral) to the Feed/mains part of the double pole switch?
My thoughts are, the double pole switch would not need to be switched on in order for the fan heater to work as it would be connected directly to the mains part of the switch and not the LOAD(where the immersion heater is connected). The double pole switch would have to be on in order for immersion heater to operate (as before).
This would essentially adding a parallel circuit allowing both the immersion heater and the fan heater to operate at the correct 230V.
Feasible?
Feasible?
