I noticed yesterday my CH was coming on even though I'd just called for HW and on inspection sure enough the 3 port valve was directing the water to both CH and HW.
I turned the system off and in the absence of anything else to try, I slid the 'slider' lever towards flushing then back to normal again, then fired it up and it seems to be working fine since. If it fails completely I'll get a tradesman in to replace it, but is there anything I can do to stop it sticking again? I see the head/actuator can be removed (2 screws) - is thre anyting in there to lubricate? I take it this can be removed without water coming out?! What is the usual reason for failure/sticking with these?
