Daisy Chain 5 x E27 Lights
29 Sep 2012
Kent
Evening all,
I'm working on a project and I would appreciate some thoughts on the solution.
The project:
- I'm creating a number of lamps from old jars, see example URL below:
http://edisonlightglobes.com/Shop/product/jar-lamps/widemouth-preserving-jar-e27-240v-pendant-light/
- The lamp fittings I am planning on using are something like this:
http://edisonlightglobes.com/Shop/p...pendant-lampholder-edison-e27-smooth-fitting/
- The flex I was planning on using is:
http://www.urbancottageindustries.c...e/dark-brown-fabric-lighting-flex-cable-twist
- The E27 lights I'm thinking of using are [60W]:
http://edisonlightglobes.com/Shop/p...n-squirrel-cage-teardrop-filament-bulb-150mm/
- I want to connect them to a single cable, with a single switch and a single wall plug so that i can put them in my living room.
- I want to link 5 of them together
- I want the wire to loop from lamp to lamp and then terminate at the end lamp
- I want to hook up a dimmer such as:
http://edisonlightglobes.com/Shop/product/plugs-and-switches/black-inline-dimmer-240v-2/
Questions:
1. Can someone please confirm that the flex i am planning on using is ok
2. Can someone explain if I need to use all 3 cores or just 2
3. Is the switch i picked sufficient
4. Can someone confirm I can wire this up to a standard UK plug
5. Can you tell me what fuse I should put in the plug
6. Ideally if someone could show ,e wiring diagram, that would be great
Cheers,
Chris
1. Yes
2. All 3. It states they are earthed.
Join the relative conductors (L,N & E) at each lamp. L to centre terminal of the lamp holder.
3. Yes
4. Yes
5. 3A
6.
------------o---------------o------------
