Hi all
I installed a Powemax Pro system and have been using the option for a PIR zone to trigger an X10 device. It works fine for a bit (a day)... then the PIR triggering stops working. The PIR ( a visonic Tower 20am) monitors the driveway and sounds a buzzer and turned on a lamp when activated. The exterior PIR works as it should, walk tested, LED comes on etc.
The Powermax can always be made to control the X10 devices from the keypad, by phone or via the web link, but the after a while the PIR zone will no longer trigger the X10 unless I go into installer mode and cycle though the "outputs" options (house code, x10 type, pulse when zone 10 is activated etc etc). X10 itself seems fairly reliable its just this one PIR will not reliably trigger the assigned X10 output.
I have checked and rechecked for programming conflicts, PIR operation etc, different house codes etc etc.... but no solution yet.
Does anyone have any ideas or experience of this?
thanks, dave
thanks, dave
