I have a Baxi 105e with an intermittent drip from one of the valves. It appears to be dripping on startup from cold - when the system is warmed up the drip stops. It seems to be coming from the spindle on what I think is the 'Heating Return Valve' - it's the one on the extreme RHS as you look at the boiler from the front.
I can't see any way to adjust the spindle seal so I'll have to get a plumber in to replace it, I think.
Despite the water scale on some of the other fittings I can't see any other leaks ( I had my head in there for half an hour last night and again this morning).
Could someone confirm it is, in fact, the Heating Return Valve.
Does a replacement have to come from Baxi or can they be sourced at a plumber's merchants?
Is it a fairly straightforward fix for a competent plumber?
Any thoughts on cost to replace?
Many thanks!
Many thanks!
