The original set up was incoming cable to NTE5 master then cable to extension 1 and ongoing cable to extension 2.
BT (subcontracted from Opal telecoms) changed to fibre supply and (as requested) made extension 1 point the new master. I am assuming the fibre is only upto the cabinet as the incoming cable was not touched.
They did this by disabling the original master point and using the existing internal cable to continue the new fibre upto the extension 1 point. Extension 2 was disconnected. Therefore there is now only one master socket.
Will the utilisation of the "old" internal extension cabling have an effect on the fibre speed available?
Could the unused pairs in the cables be used to connect the front half of the master back to the original master point so it could be used as a phone extension? And could the extension 2 be reconnected to the master to bring it back into use. I can't see why not but the BT guy advised against this.
