Would it be ok to use this spare 32amp for the garage supply
![770ba1e75c36f3a9cd72efe50a9f9ef4.jpg](http://i1094.photobucket.com/albums/i441/ross2057/house electrics/770ba1e75c36f3a9cd72efe50a9f9ef4.jpg)
![0bccfa89ef07e241fbb9a7b005b25749.jpg](http://i1094.photobucket.com/albums/i441/ross2057/house electrics/0bccfa89ef07e241fbb9a7b005b25749.jpg)
If you have to ask that question then you must not do any electrical work whatsoever.to put the 20amp rcbo in its own encloser next to the consumer unit, do u have a diagram how it's wired up please
You mention in your other post you plan on using a welder in your garage.
A welder will take out that breaker every now and again, and will take out your 20A RCBO 7 times out of every 10 times you turn the welder on.
Thanks, now that's what I don't want to happen, so what would be the best design, could you give me a list of all the require parts so I could order source the parts then get a electrician to fit them![]()
Will it? I have a shed at the bottom of the garden, with the electrics connected back to the consumer unit which is an older style with just the one RCD (and a bunch of MCBs) and the welder has NEVER tripped either the RCD or the MCB. (Its a 150A welder and I've had it on full power). Why would it in the above planned installation?
