Nobody is going to tell you to fit a PCB on this. You're now in 2 posts, why add another? If this particular boiler hasn't been serviced for 7 years I'd be worried.
Stop messing around and get somebody in, to diagnose fault firstly then service. You will be looking at £150 if the PCB is the ONLY fault, which I doubt.
Sorry for posting twice, I had got some one, he took 1 look and said PCB? Without touching the darn thing, he said he has dealt with the same problem 3 times over the last 2 weeks
Not made of money, I have asked another so called specialist to come over and tell me the same thing without touching the boiler?
Why would a PCB fail Rgill? This boiler is very notorious yet you still believe in the specialists? Fit the ebay PCB all you like, not my problem.
What are the symptoms??
I can see antagonism on both sides of the debate here, but as a DIYer, I would point out that it's not a good idea to try repairing your boiler if you don't know the basics of how it works.
I do not know this boiler, or why it is notorious either, but a quick internet search reveals it is a premix boiler. Boilers of this type have to be set up properly with the right equipment in order to be safe - they can be finicky things.
If you are intent on changing the PCB yourself, please educate yourself with what you need to know before you start the job. 'Pressing and guessing' won't be a good idea, could result in an unsafe situation, and could end up costing you more than professional help.
I would recommend that you get someone in if at all possible.
Mogget.
