Dont bother getting a new syphon replace the old one with a Flapper valve, simple to fit and trouble free.
This is the worst advice i have heard this week, do not fit a flap valve.Dont bother getting a new syphon replace the old one with a Flapper valve, simple to fit and trouble free.
Thanks is a newly installed toilet so should the diaphragm be ok could it be a faulty one?
If it's a Dudley Turbo 88 they work (illogically) the other way round:The thing is todays WC's are dual flush. So a lever version gives a short flush with one push and a full flush if held down.
Thomas Dudley said:Dudley Duoflush delivers water-saving reduced flush when lever is held down and full flush when lever is depressed and released.
For what reason do you say that, what problems have you come across with Flapper valves ? These are widely used across the World especially in Europe and the USA
Fitted correctly there are no problems, one just has to get used to using them.
I have replaced syphons with flapper valves for customers and as to date have never received any complaints just good reviews.
Just because other countries might use them gives no validity or merit to your argument, they stone people to death in the middle east, should we start doing that here?
You are also trying to suggest that they are popular in these countries, this is false, they are used as sparsely as they are in the UK.
There are no benefits to a homeowner having one of these fitted, because there are absolutely no upsides to having one and nobody would ever ask for one, so i don't understand why you have ever bothered fitting them for your unfortunate customers, let us hope they are not on a meter.
They should be banned, again.
whereas debris can chew up a diaphragm on a syphon valve within a few days of fitting it
If its the traditional syphon, maybe the water level isn't quite high enough?
(If the diaphragm is known to be OK)
John![]()
