Oh great
Called to a fault on a socket circuit.
First job was going to be to whip the ends out the board and IR test the circuit.
:x
What IR readings did you get at the CU ? did you advise the customer it would be wise to sort out the mess within the CU ?
edit grammer
Getting back to the original subject....
RF, did you turn it into one of your works of art (which I've tried to emulate) when you put it all back together?
If you hear buzzing coming from a bus bar, something is very wrong, and quite likely to become an awful lot more wrong.
2nded. pictures if you did like to see a neat CU
Sadly not. It would have needed the board stripping right out and starting again.
I ended up fishing the wire ends out the back of the board with my long nose pliers.
Forgot to mention, this is an ex HA house, and was rewired in a day by five lads. It shows...
