Hi folks, I found this forum when I was looking for a bit of help with a 2 MCB fused consumer unit I'm going to install in my workshop.
OK just to outline what I'm doing, (in order to get the best advice I can), I'd like to double protect my tools and workshop by having a single cable from the house consumer unit powering the workshop consumer unit which in turn will have a fuse for the lights and a fuse for the sockets.
Now, having done a bit of research on this, I find because I'm going to be running florescent strip lights, (a total of 4 of them each offering 58 watts of light), and several transformer based 12v halogen lights as well as 3 energy saver light bulbs drawing about 18 watts each.
So given this, would I be right in assuming a 10 amp fuse on the workshop consumer unit will be more than enough? I have read a 6 amp should be fine but because I'm running halogen lights with transformers, (a total of 4 of them all wired to its own light switch), they tend to trip out 6 amp MCB's.
Would I also be right in running a 16 amp consumer fuse for the sockets circuit?
I'm going to install a total of 8 double faced sockets with each socket unit running a 4 strip surge protected socket.
Now, the biggest consumer units I'll be using are a 150 amp Arc welder, a 100 Amp MIG, a 768 watt or 3.2 amp compressor and a 1,100 watt table saw though not at the same time of course
The maximum draw on this will be:
All the lights, (4 halogen 100 watt transformers), plus the 4 strip lights, a stereo amplifier and perhaps the table saw and the compressor at the same time though the air tank on the compressor will be fully charged and it'll only flick on to top the tank up from 50psi back to 110 psi.
Given this, would I be better using a 25 amp MCB on the house cosumer unit or a 32 amp?
Everything in the workshop runs off a 13 amp fused plug so nothing is wired into the system directly.
I would also ask, would be better off putting a radial circuit or a ring circuit for the sockets?
Of course when it comes to wiring into the houses main consumer unit I will be calling in a qualified and registered electrician rather than doing it myself.
I'll add, so far I've been running the lights and sockets off a single 13 amp fused plug with no issues at all but I'd like to change that to a more permanent and professional solution that will offer me and my tools better protection from surges or the risk of electric shock.
Also, would I be OK to run a single light off the plug sockets? It's just that of something did go wrong with the lighting circuit, I feel it's not a good idea to be plunged into darkness while running material through the table saw since I like my fingers where they are
Thanks for the help
Thanks for the help
