Another Soil Pipe question with image
5 Jun 2012
I need to connect A to C via B. The horizontal distance between A and the wall is about 70cm. The vertical distance betwen A and B is about 1.4m. The vertical distance between B and C is about 1m. The horizontal distance between A and C is about 1.4m
So issue is, I'd really like to keep soil pipe close to the wall between A and B, but between B and C it doesn't matter. Ideally, I'd get from A to B using three 90's, from A turn right, turn down, then turn right to get to B. But this would mean connecting 2 x 90's on top of each oither immediately from A due to the tight distance.
I could live with using 2 x 135's between A and B, using a single 90 between B and C.
Any thoughts?
Added - this is a plan view!
So issue is, I'd really like to keep soil pipe close to the wall between A and B, but between B and C it doesn't matter. Ideally, I'd get from A to B using three 90's, from A turn right, turn down , then turn right to get to B. But this would mean connecting 2 x 90's on top of each oither immediately from A due to the tight distance.
Any thoughts?
Sort of confusing unless you expect the waste to go uphill! - From A you say turn right ? you mean left? Then you say turn down (on the way to C!)?
You don't have all the dimensions needed for a constructive solution so I would suggest you add more information and retype the lot!
Hi - it's a plan view, looking from A - so waste doesn't go uphill. So I do mean turn right looking from above. I think I have also highlighted some measurements that are sufficient to describe the situation (I use the term vertically and horizontally in respect of the diagram, so you know the distances I mean - it's not "literally" vertically).
Any thoughts?
I see what you are trying to say now. Its a good job you don't read drawings for a living!
You need the distance from A to the wall on the right i.e. from centre of the pipe to the face of the wall with B in it and not approximate.
You need distance from the "top" wall to B (again centre of pipe)
You need the "left" to "right" distance from Wall with B in it to C
You need distance from C to the "top" wall where C is the end of the pan outlet.
Show the wall thinckness's
All measurements should be to the centre of the proposed pipe. "Approximate" does not cut it if space is tight.
For two 92 1/2 degree bends together consider using spigot/socket bends
If any of the pipework is concealed consider using solvent weld fittings.
Allow for the space brackets take up
Using your terminology, is there any reason why you can't go up from C through the wall and left across to A then a vertical drop at one end or the other for the height difference
