Moving a double socket
25 Sep 2008
Renfrewshire
Hi Guys
Just looking for a bit of advice on moving a socket. In my hallway there was a 2m x 1m recess in which I have built a partition wall across to create a walk in cupboard. At the back of the recess is a double socket which I would like to move on to the front of the new partition wall.
What would be the best method? To extend the two 2.5mm cables with connecting block and put a blanking plate on the original box? Or spur a new socket from the original?
The blanking plate would be accessible but wouldn't be a good location to keep as a socket. Also this is the only one in the hallway.
Thanks in advance for your advice!
Kev
It would be preferable to extend the ring using two cables, rather than spur.
Note you will need 2 x 3-way connecting block to extend each cable separately.
Hi, I have done the same thing a few years ago. I assume the socket box is recessed?
I took a spur off to a new switch.
I removed the switch plate & box and terminated the cables ( you will have 2 reds, 2 blacks & 2 earths?) in a junction box which stayed on the wall inside. The new switch box was fitted into the wall & the cables routed through cable trunking to the junction box.
The old socket position was filled up with a piece of plaster board and skimmed.
regards keith
regards keith
Don't do this as screwed joints must be accessible. You could do this and then use a blanking plate on the existing back box instead which will remain with the regs. (You can get flush fit blanking plates as well).
Thanks Eddieed.
By screwed joints do you mean the terminals in the junction box?
Incidently it was a friend of mine (who was a contracting lecky with more qualifications than i would ever have), who suggested the job.
Possibly the rules have changed as it was 15 years ago! thanks for your replies folks, regards keith.
