issue
27 Nov 2013
Yorkshire
Just to let you know it is the diverter valve that needs replacing.
Does any know if its possible to turn off the pre-heat on this boiler?
Yeah, definitely, turn the widget three degrees SE of the radius on the circumference and all will be clear
  • Thanks
Reactions: DP
Preheat on which boiler?
Why do you think the diverter valve needs replacing? Are you a boiler engineer?
using my crystal ball I can see a ideal isar, wait I can see a preheat that you cant switch off and a stuck diverter valve meaning the rads are hot all the time........how am I doing? :wink:
sorry it was the ideal isar m30100, landlord is fixing it tonight.
also i meant to put this on my original thread oopsie
