Thanks for replying Chaps!!!
A few questions
>>Subject to the timber lintel being sound I would be inclined to leave it >>insitu
When you mention the timber lintel, are you referring to A or B or Both (I’ve labelled them below)
>>Prop it whilst you cut out the old window frame head and brick up the >>bearings.
Where would the props go exactly? Below A or below B?
Are you saying to remove B and brick and concrete below it to make up the space up to A
(A doesn't extend any further left than you can see in the picture, it's not in contact with any bricks apart from those above it)?
>>However you'll need to check - What size is timber lintel; is it hardwood >>or softwood; how wide is span; what load is it supporting etc.
1.9 m wide with about fourty rows of bricks, a window and a roof above. Looks like hardwood from what I can see.
A few questions
