Hi guys
Just to double check that if a MPBC is to be surface mounted external to the property we do not have to increase the CSA size?
I've been asked to change a consumer unit and there is currently no MPBCs. The gas meter (external) is about 3 meters away from the wall where the CU can be found, so I intend to make this run of cable external and as far as I can see there is no requirement for additional protection or upping the CSA.
Regarding the water supply the cut of is located in a position where I can't hide the cable or run it up into the ceiling. There's no reason why I can't run this cable in trunking along the skirting?
Cheers,
Chris.
Cheers,
Chris.
