I've never had a spurious reading from a needle or a segment go duff turning an 8 into a 9 or 3 or a 9 into 7 etc..They're commonplace everywhere because they're cheap to manufacture, and that's all.
And versatile, and precise, and reliable, and durable..
There's no right or wrong; just personal preference.Boys and girls! let's keep the toys in the pram!!!![]()
And versatile, and precise, and reliable, and durable..![]()
Yes, but for most purposes you don't need anything like that accuracy to such tolerances.
I think you may have just made my point though bud. I was told a long time ago that it hasn't been 240v in my area for yonks and 230v is the norm. But did anyone know or care? Did our equipment stop working?Yes, but for most purposes you don't need anything like that accuracy to such tolerances.
And if, say, you wanted to determine if your house was supplied with ~230VAC or ~240VAC?
I thought you were going to be biased, but I give cred where due ta.
IIRC Fluke were the first, that I saw, introduce a bar on their meters to mimic the feel of a needle. (Mid 80s). But it still didn't have the same feel for me.
Bit like, to use another car analogy, the simple humble switch. Not simple anymoreI can tell when I use the flash on Maria's Fiat it goes through a PIC and/or relay. There's a fraction of a delay while clever stuff thinks about it.
KISS please!It's unnecessary, more expensive, more complicated and us DIYers can't do a thing to fix it. (Deliberately so).
In many modern vehicles, there is no relay operating the indicators or lights, and in fact, no special wiring. They run DC power and a data line out to each light cluster, and instruct a controller in the cluster to electronically switch individual lamps. There is a very slight delay to switch all this stuff on and off which may be perceptible.
On the other hand, it actually greatly simplifies things for the vehicle manufacturer. They no longer need complicated wiring harnesses, all testing can be done electronically, actions can be performed electronically which would otherwise require mechanical interaction. Features can be added to vehicles without requiring a change or addition to the wiring harness, and faults all around the vehicle can be identified and reported without requiring extensive inspection.
Yes, it adds complexity from the perspective of the user/owner, as they remain ignorant of the functionality, however, that is the nature of advancing technology. I rather like this system (vastly lower chance of wiring faults, for example), however, it is very awkward to interact as they keep all the fun stuff in proprietary protocols (and yes, a large part of that decision is to keep money flowing through their dealers, other issues relate to safety, and I suspect more than a little fear of criticism!).
I'm not sure it does simplify things? You've had to build and design a microcontroller for each lamp cluster which costs more than some simple lamp holders and some wire (and the lamp holders and wire are there anyway!)
You've also had to design and build a controller inside the car which takes all the inputs from the stalks, processes them and combines them into a data signal and sends them to the microcontrollers out in the lights. Just like different models of car would previously have had different looms, you've now ended up with different microcontrollers for each type of light, ie the model with the HID steering headlamps will have a different controller to the model with the basic non-steering halogens.
You've also now got fragile electronics mounted in a hostile environment, rather than simply having some copper wires, which is not really good for reliability or longevity, especially with the crap solder they use these days.
Very true - just as with a vast number of other products these days. Indeed, a very high proportion appear to be designed and manufactured on the basis that repair (other than, sometimes, 'module replacement') will never be attempted (or possible).Modern cars are designed for easy, fast and low cost assembly with little thought about ease and costs of repair and maintainance.
