I'm planning on replacing the cable to an outbuilding with SWA. Its currently installed with some T&E shonkily buried in the gravel with no protection and an oversize breaker, and clearly needs to go. Weathers getting less crap now, so want to get the details sorted so i can get the parts ordered.
Its currently connected to an MCB in a old secondary CU that will be disappearing shortly so the plan is to install a switchfuse in its place.
There are various switch fuse options, but not too happy with them. The metal clad ones seem to be hugely oversize for some reason, and the 800KMF is nice and compact but has no provision for terminating SWA into it given its plastic construction, meaning the addition of an adaptable box or similar, which then ruins the compactness and aesthetics.
I would also like to build in provision for another outbuilding supply, for a garage i will be building later in the year, and having two huge switch fuses mounted side by side will look a bit crap.
What i'm wondering, is there any reason i cant use a "normal" Metalclad CU enclosure, bring the tails into it and use a two pole isolator and a din rail mounted fuse holder (or even an MCB?) to protect the SWA?
As an example; this enclosure with suitable parts installed:
http://www.ebay.co.uk/itm/321335958690
A second isolator and second fuse could then be installed into this enclosure with minimal effort, when it comes time to run the supply to the garage.
Thoughts?
Thoughts?
