Hi
We've recently moved into a new house and are busy decorating, we also wanted to upgrade some of the insulation and install underfloor heating in bathrooms and hallway.
One part of the house is a 1980's extension and my intention was to lift the floor, install insulation along with underfloor heating and replace. However, upon lifting the floor in the bathroom I've come across a bemusing situation whereby there appears to be a concrete slab with joists laid over the top of it with various shims to level, the variation from one side of the room to the other is from a 5cm joist to 8cm.
Due to the random levels and spacing of the joists laying insulation would be very difficult.
My thoughts were that I would have to use self levelling compound with maximum variance been 30mm, then lay insulation and underfloor heating.
Due to the depths involved I'm likely only going to be able to lay 20mm insulation - will it be worth it?
Are there any other options?
Robert
View media item 76426
Robert
