Like I said, it's not a problem - when these properties were built, insulation was something they'd heard of. And I'm well aware of the purpose of overcurrent protection thank you very much.And talking of standards, it is the protection of the circuit and the conductors that are of relevance, not the loading. The whole idea of overcurrent protection is to protect cables from damage, and thus your property.
All the works were notified etc.The electrician extending the radial into a ring should have notified this via their certification body and filled out a certificate.
Perhaps if you feel it is such an issue, pointers to what you think may be an issue and the appropriate regs would be in order. Just suggesting something isn't to regs isn't helpful (especially when I've got certificates that say otherwise) - BS7671:2008 runs to 380+ pages, about 250 without the appendixes and tables at the back.Since you are feeling so pedantic, i think you should also read up on the requirements for power in a garage and plastic soil pipes passing through buildings. I think you'll find your ring to the garage and your expanding foam need looking at.
This will keep you busy in the meantime.
https://www.hse.gov.uk/forms/incident/f2508g2.pdf[/QUOTE]
Ah, yes. That seems a more appropriate form than RIDDOR - but I'll wait until contracts are exchanged before I start stirring on that one.
Did not read your entire post but flexi flue liner is only suitable for lining flues not to be used as per your photos in the loft ! bodge up !
Well the vendor has now paid an unknown sum to have it sorted. Somehow I don't think I'll be on his crimbo card list - what with insisting he fix this AND repair the broken boiler he wanted to palm off on meDid not read your entire post but flexi flue liner is only suitable for lining flues not to be used as per your photos in the loft ! bodge up !
i think you would need to spend a few hundred quid on this just to get it up to be being a bodge![]()
Still no expansion on that ? You seem to be implying that something is wrong, but giving no hints whatsoever as to what. As such it's a completely unhelpful comment.Since you are feeling so pedantic, i think you should also read up on the requirements for power in a garage and plastic soil pipes passing through buildings. I think you'll find your ring to the garage and your expanding foam need looking at.
Well the purchase is now complete, and what's more the receipt for the fire is in the file of papers I've been given - so I'm able to identify the installer (it's a local fire appliance showroom).
Just to add to the above comment this is untrue, everyone has been very very lucky that's why most gas appliance have flues that directly terminate outside to atmosphere.it's a fairly well ventilated loft so it's unlikely that anything serious would have happened.
OK, I'll clarify what I meant. There's a large space in the attic, the gas fire would only have been used intermittently if it had been used, and the attic is well vented - there's a continuous soffit vent along both sides (vary large total vent area). There's aren't any significant gaps in the ceiling, so any POCs would have to permeate through the plasterboard to get into the living space.Just to add to the above comment this is untrue, everyone has been very very lucky that's why most gas appliance have flues that directly terminate outside to atmosphere.
