Mountfield mower deck rust!
2 Nov 2009
my self-propelled Honda engine mountfield is now 7 years old
I regularly clean it (mostly :oops: )
however much to my horror the paint has now come off attached to crusty rust :shock: - this being in the underneath cutting area.
Rust has not affected the integrity of the deck but I need to fix it!
Plan is to use a rotary wire brush and then use "hammerite" x 2 coats
Question is should I use a rust converter first or...........any other suggestions?
They all catch you out, don't they......sure, use rust converter (pink solution, turns black), then primer then Hammerite.
If the deck has holes and can be patched, consider Halfords fibre glass repair kits.
John :)
John :)
No John no holes (yet!)
If I do it properly now I should stop it
its time they started selling replacement decks I notice a few threads on here about them rotting away which is a shame because the Honda engine is bullet proof and will outlast me!!!!
Even the genuine Honda steel decks rust just the same - a new small Izy deck is around £70 but there's lots of time to be spent swapping the bits over.
What you are doing will extend your mowers life by years.
John :)
