Spraying kitchen cabinet doors.
13 Jan 2008
Hi, as above, has anyone used spray cans for this job if so, was if successful, and what make did you use, thanks for your time!!
You can spray almost anything if it as a) keyed b) degreased c) primed correctly.
I assume it's currently a smooth melamine finish or similar?
Nozzle
Nozzle
Hi Nozzle, thanks for your reply. Yes it is a smooth finish, also looking for recommendations for makes of paint in spray cans!
I'd have a go with ordinary acrylic paint. Like all good paint jobs, the key is in the PREPARATION. Use a good primer first and keep the dust away, if you're spraying in a garage on the dusty floor or something like that, sprinkle the floor with water first to stop dust kicking up. Many light coats are better than few heavy ones, and be methodical with your spraying pattern. Push the button of the spray can so the spray starts off the work piece, then move the can across the work piece.
Nozzle
