I'd have a go with ordinary acrylic paint. Like all good paint jobs, the key is in the PREPARATION. Use a good primer first and keep the dust away, if you're spraying in a garage on the dusty floor or something like that, sprinkle the floor with water first to stop dust kicking up. Many light coats are better than few heavy ones, and be methodical with your spraying pattern. Push the button of the spray can so the spray starts off the work piece, then move the can across the work piece.
