Bending PVC Overflow Pipe
19 Jan 2006
West Midlands
I'm using some PVC overflow pipe as a condensate drain for an indoor air con unit.
Is there any issue with heating this up and bending (with a spring or sand) to minimise the number of angled bends. It runs behind a plasterboard wall, so want to be able to push a wire down it in case of any future blockage.
Many thanks,
Damian
you can bend alot of it with a 22mm copper pipe bender , providing its newish pipe
I've used a bending machine in the past, but always have problems retaining the bend when the pipe cools down & using a blow lamp, getting an even heat on the pipe prior to bending. Overheating certain bits & leaving black scorch marks.
I'd be interested to read what methods others adopt.
PS: Fafing around with corks & sand is just not practical onsite, where time is money!!
If you have a pipe bender use it, if you want say a 45 degree bend, pull it to 90 degrees and keep it there for a minute, when you release it it will pull back to where you want it, approximately i mean. I do it all the time.
