Just like to add, nothing manly about not fearing a potentialy dangerous tool.
Just to add my cousin many years back using an angle grinder didnt use 'girly goggles', a metal splinter pinged off his work and pierced his eye, he ended up needing a new lense fitted in his eye. He now has one eye like a cateye. And believe me hes not happy about it.
Ive always used grinders big n small, although most of my cutting work on stone i use a steel diamond turbo style disc, i dont like fibre discs. Never once had an incident but this is good to remind me to respect these machines.
Always be firm, a good stance, be confident, never push hard on the disc, take small amounts off. Dont use the side of a blade on fibre cutting discs.
When cutting always push the cutt against the direction of the blade's revolution. Ie if youre standing over your work and the blade is kicking out debris front to back start 'upstream or the top of the line' and work back towards you. Otherwise the blade can kick and run back easier and youre already moving that direction.
Whoever commented on using the side of the blade to debur should be careful also.
This is a wakeup call for me as i normally use just my glasses as eye protection. Going to buy some full goggles from screwfix today. New eye lenses £3000+ each (if they can be fixed) or new goggles say a tenner.
Hmm
Someone mentioned check the collars?
