You need to talk to a local old boy builder. You either replicate the old way and have big chimney breasts, open hearths, and cooler rooms or go the modern route and use vapour barriers. Only someone who can see the house and knows what they are talking about can advise you.
Thats what I've had. 'vapour' barriers would surely just trap moisture in the wall causing it to eventually fail? The cement render would eventually fail also due to moisture underneath?
You have two choices. Go the old route and ventilate or go the new route and create a damp free environment inside the house. No-one on here can tell you which is best as they can't see your situation.
After the specialist inspections it seems the best route and only route is to put the house back to as intended. Consensus amongst the pro's seem to be that applying modern methods will only remove the issue as it'll be hidden, which would cause lots of problems further down the line.
Better to sort the cause of the issues out.
So lime render per sq m!? Either that or I guess I can use an air powered applicator which will give a dimpled finish?
