Morning all,
I have the current setup at the rear of the house,
There are two spot lights on the left of the house turned on/off with a fused switch spur from inside,
There are two spot lights on the right of the house turned on/off with a fused switch spur from inside,
So two separate switches to operate the two pairs of lights.
I have attached photos below and as you can tell they are not up to much and are on their last legs. Whilst checking the lights over i found that the left light of both pairs has a permanent live supply (T&E) and then a switched live running to the light switches within the house.
Now while i would like to update the light fittings which should'nt pose a problem i would also like to integrate a security floodlight on a PIR which isn't dependent on a light switch to work but could be turned on with a light switch for BBQ's etc,
What would be the best way to achieve this?
My current mindset would be to swap the new light fittings for new ones and then run a length of flex to the security light from the fittings with the permanent live, would four core allow the permanent live to be carried to the light fitting and then a switched live to be able to turn the fitting on manually....
Any advice would be appreciated,
(I was previously considering LED flood lights (mentioned on the forum) but until the cost comes down and reliability is proven i'll be sticking to halogens)
