Hi everyone. A few words of advice would be appreciated after I got round to looking into a few electrical issues in my conservatory today (it was built long before we arrived here BTW).
There are 4 double sockets in our conservatory. 2 worked fine but the other 2 sorry of half worked. I tested the voltage at the ones that didn't work and got 210. Took face plates off and found supply to conservatory is a single 2.5mm cable which terminates in the first socket. From there there was a slightly fried 1.5 which having disconnected it clearly supplied the next 2 sockets in line. The fourth socket turns out to be a spur from kitchen see below.
For now I disconnected the thinner cable and still use the socket that works- anything else I can do?
Worried now i moved on to another problem with a fuse in one of those fused switches in the kitchen which has blown a few times. It is above the dishwasher and I had assumed it supplied the single socket the machine is plugged in to. However the fuse blows when the dryer and or washing machine are on at the same time-through wall in conservatory. Thought better have a look today and sure enough supply goes double socket on 2.5mm ring > spur fused switch thing > dishwasher single socket > double socket with dryer and washing machine.
Most sensible way to fix this dopey arrangement?
Sigh
Thanks in advance
Sigh
Thanks in advance
