Hello all.
Trying to sort out a shower that is not draining so quick.
General pic
Close up of trap and components
I've cleaned out the trap and it still seems to not be draining quick enough, with a steady build of water in the tray during use.
I've used the usual supermarket pour-down drain unblockers before with some success. At one time it stopped pretty much completely and we then got a plumber who got it going again by pouring some very strong acid down.
I want to try and fix more thoroughly now. I'm aware pouring strong stuff down won't be good for the pipes.
I can feel down inside where there is a small opening. There is a waste pipe that runs along in the boxed in section. The small opening in the trap is on the left hand side, so I guess the pipe is here that joins up to it, with a small run and joining with a 45 or 90 deg elbow.
I have a small flexible cleaning spring, but when I push it down and round into this opening, it won't go in far.
I'm not sure of the layout of this type of trap - any advice from the pics? Is it not possible to unblock in this way, due to their design?
I suspect it is a cheap trap, but I couldn't see any obvious diagrams on line.
With a kitchen sink, I've taken apart the u bend and manually cleaned out. This doesn't seem a viable option here. I don't really want to start pulling the shower apart, not sure if the plastic strip by the floor is intended to come away easily and put back/reseal?
Suggestions appreciated!
General pic
