- Joined
- 27 Jan 2008
- Messages
- 28,488
- Reaction score
- 3,459
- Location
- Country
To have two outputs usable at the same time will require two separate secondary windings on the transformer the whole idea is a very limited amount of power, socket on only when plug inserted and since only one item used very little chance of multi faults causing both live wires of being touched at the same time.
If you want two outputs then fit two sockets. Do be aware not all shaver sockets are rated for continuous use only if it has picture of tooth brush on it can it be used for a tooth brush.
these sockets which would allow 2 to fit in a duel back box
