And this forum is dedicated to the electrical trade, so enough said!'Correct' in the eyes of the electrical trade,Lamps is the correct term used for bulbs.
Because they are not designed for lighting up rooms - the clue lies in spot lights.I asked for spotlights in the rooms, again what is wrong with having spot lights?
Nor should you - your obligation is to prove that the work you do complies with the Building Regulations.Yes I could buy florescent if I wanted to and get better energy but I'm not trying to compete with **** building regulations.
No it isn't.It's up to me whether I have halogens or florescent
Ultimately society cares. That's why we have these laws.who even cares?
I think you'll find that most LABCs follow the official guidance and insist on a minimum % of fittings that will only take energy efficient lamps.It's a case of changing the bulb !
You of course are free to enter into a dispute with them.
Because you are not competent to do it.Why would I need a designer for christ sake it's a 2 bedroom rewire?
Not so much a problem, more that we recognise your lack of competence.What on earth is the problem with some of you, need to cheer up.
Care to show where?and then people moaning about having a **** architect doing CAD drawings or something for the electrics.
Likewise, I'm sure.Don't be so stupid.
Go away and get a proper electrician do do the whole lot.
Quite. How you light your house is entirely up to you, and as for some of the electrical trade's unilateral decision to re-christen bulbs as lamps ...!! However, some people have bees in their bonnets about both those topics!Does it actually matter how many people have spot lights in their houses? And the correct definition of a light bulb...
If, as you seem to be suggesting, many/most of your lights will usually be severely dimmed, that's fair enough. The point being made by some, with which I would agree, is that 200W-300W worth of lighting (non-dimmed) would be very excessive for all but very large rooms. However, some of those here just 'have a thing about' downlights and spotlights, and will say rude things about them no matter what the power or degree of dimming!
I may have missed that - the only figure I recall being quoted was £450 - which, with true trade discounts might be just about do-able for some houses, with fairly modest requirements....whoever said £250 materials to rewire the whole house is clearly thinking of one standard sh1tty pendant in each room emitting dungeon light
You need to be fairly selective in terms who you take much notice of, and who you 'take seriously', in any forum like this.
Those were the days, not pre war but the 1950's when people were polite and accepted advice without giving rude comments when the advice was not the advice they wanted to hear..I guess in the age of some of you guys, pre world war you'd be lucky to have a working light in the house, things have come some distance since then.
Good luck with all those dimmers. You are aware that many cheap dimmers create so much electrical noise on the mains that other dimmers become unstable.
Dimmers work by chopping the power on and off. To prevent the dimmers creating a lot of internal heat the switching has be as rapid as possible, from ON to OFF in a few micro-seconds 100 times a second. ( slow switching creates heat in the switching device ). The rapid change in current causes voltage spikes and dips on the mains ( electrical noise ) and these spikes and dips confuse other dimmers.
Not only that but they cause radio interference to you and your neighbours. If you don't believe me try listening to radio 4 on long wave with them operating at half brightness.
If you want to control room brightness best to have say 3 sets of lights and only switch one of two on.
Ban likes a bulb suspended from the ceiling as its lights a room well.
If you want spot lights, which light a small space they are expensive to run as 50W, but if you fit LEDs then they are fine, but maybe a bit too white for some rooms.
Then you're buying s***te? Or that's without VAT
If they aren't suitable for dimming they wouldn't sell them would they ?
That's with VAT, and it's not s***te. This would be a good time to point out I've done electrical work and you haven't; I know good hardware from bad, you don't even know what it's for.
If cars weren't suitable for driving underwater they wouldn't sell them would they?
So if I buy expensive florescent bulbs for every room this would satisfy everyone here ?
Better still get LEDs, 50W equivalent under a fiver.
http://www.homebase.co.uk/en/homeba...le-bulb-gu10-5w--50w----1-pack-246316[/QUOTE]
If I buy these bulbs, is the same wiring used that would be used for halogens, and are transformers etc required? Again, sorry I'm not a sparky I'm helping an ex-sparky to run the cables, so if this is a stupid question apologies, and I'm sure he will know which to use anyway. Just asking for my own education
As so often, "it depends". As a general truth, any arrangement of lighting which requires 200W-300W (undimmed) for a normal room is seriously (many would say 'ridiculously') inefficient, not to mention very expensive to run (300W for, say, 6 hours per day would cost around £100 per year to run, just for one room). So, in that sense, 200W-300W is very much 'excessive'.And John, with regards this comment ... 200W-300W worth of lighting (non-dimmed) would be very excessive for all but very large rooms. ... Someone said earlier it would be insufficient having spots... So if I've 50W, 4 for a bedroom say that's 200W of lighting on full... the word earlier was this is insufficient? But your saying to much ? Which is it ? I'm having 6 in kitchen, 5 lounge. [/b]
